When machining the part on the subspindle, there is a positive z
StefansB
Message 1 of 15
StefansB
Hello, why is there a positive z on the subspindle?
It is expected to crash!
Is it because I posted both sets at the same time?
Replies (14)
Message 2 of 15
seth.madore
What post processor are you using?
The Setup (in Fusion) for both spindles is the same, it's required that the post processor handle the inversion of the Z axis (and related arc moves). My Doosan Lynx is similar to your machine (as far as Z needing to be negative for retracts)
Seth Madore
Message 3 of 15
StefansB
I use Doosan postprocessor.
I don't understand how the setup should be the same and how, for example, can the arc movement be applied to the facing operation?
Message 4 of 15
seth.madore
Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Message 5 of 15
StefansB
Already attached
Message 6 of 15
seth.madore
oops, thanks. Didn't notice it.. 🙈
Seth Madore
Message 7 of 15
seth.madore
Are you using the generic Doosan post, or one of your own modification? Using the generic Doosan post, I'm getting this code (in the location indicated in your photo):
G1 X40.2 Y0. Z-1.766 F0.134
G0 X37.643
G1 X36.531 F0.1
Z0.234
X38.531 Z1.234
X42.531
M9
G0 G28 U0. V0.
G28 W0.
M110
M1
N11(IEKSEJAIS RUPJAIS)
Seth Madore
Message 8 of 15
StefansB
I am using doosan postprocessor with last update.
But look at the code below, there is Z positive.
Message 9 of 15
seth.madore
What are you using for a machine? When posting out as a Doosan Lynx(with Y), I get the same exact code as what I posted above. Are you setting any user properties?
Seth Madore
Message 10 of 15
StefansB
I use on post settings safe retracts and home positioning.
Move to Z-home positions - WCS
Z-home positions 400
Message 11 of 15
seth.madore
Right, well aware of the Simulation limitation. I was asking about which machine you were selecting here:
Seth Madore
Message 12 of 15
seth.madore
But your response above gives me the settings I needed to know. For now, I would avoid those settings. I'll get this logged and we'll update the post processor.
Seth Madore
Message 13 of 15
StefansB
Message 14 of 15
seth.madore
We've opened up CAMP-2693 to fix this issue. If you wish to continue using your Post Processor with the non-standard Z home positioning, you would need to edit your post. You can do this by:
1: "Comment" out the following lines in "onSectionEnd":
  /*if (getSpindle(PART) == SPINDLE_SUB) {
    invertAxes(false, false);
(Notice how it has "/* and */ in there? That's what you need to do)
2: modify the following code in onSection (at line 2091 in the latest version).
  // invert axes for secondary spindle
  invertAxes(getSpindle(PART) == SPINDLE_SUB, false); // polar mode has not been enabled yet
Seth Madore
Message 15 of 15
StefansB
Thank you for finding the solution and quick response.
