When creating a new tool T# changes but the H# does not?
jgaertner
jgaertner
Hello Forum.
So, I am pressing on with my education on Fusion. When I create a new tool, the G code shows the correct tool number. For example T7 but it does not show H7 for the tool height? I have to change it by hand in the G Code editor on my Tormach before I start running the G-code. Itis not a big deal but one day I am going to forget and there is going to be a problem!
Any ideas?
Jgaertner
Steinwerks
Make sure the tool offset numbers match in the project's Tool Library. And you'll probably want to check the library where you're pulling from as well.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
As Steinwerks said, the Length offset value is what is pulled for the H parameter while the Number is used for the T parameter.  You'll need to make them match on the <Post Processor> tab if that's what you want.
Dave
jgaertner
Thanks for this help. I did try setting the tool H value to match the tool #, but when I run my post it the H # reverts back to 1? So I have to remeber to change it by hand in the code before I try running the code on my mill?
Jgaertner
Did you update the tools in your document too or just the library?  It may not have picked up the edits...
There should be no reason to need to hand edit - especially for something like this.
Dave
Your update tools in document tip is all I was missing. Now I can stop banging my head.... 🙂
