Its the design! At first I thought he just wanted to cut it using a constant ramp, not that the features are actually sloped.
You can make a 3D toolpath using Trace and left compensation. but keep in mind due to the radius you will be back-cutting with is as it goes down in Z. Only safe way to make it like the model is physically tilt the part.
If's about the angle, and not the surface then trace could be enough. Be sure to add some lead ins and everything required to make it not collide.
FYI 2D toolpaths means it goes off 2d geometry lines/part faces NOT that it is confined to a fixed Z height. The 3D in 3D toolpaths just means it goes off your 3D MODEL for geometry.
File re-attached. Add some lead ins and another DOC and you may just be on your way (duplicate it, add axial stock to leave)
Please click "Accept Solution" if what I wrote solved your issue!
