What's the easiest way to remove cusps on open pockets?
CuttingEdgeManufacturing
Message 1 of 9
i've always struggled through the 2d pocket operation on F360.  if i were to select a boss or something that is below the model top but not necessarily a pocket "per se" it always leaves cusps along the edges. which i understand because the pocket selection is enclosing the entire area. to get away from this problem i can make it an open contour, but then im machining tons of air. especially on larger parts. the only other thing i can think of is to draw some sketches around the areas i want. but this is a slow process.
what is a better more efficient way to program these surfaces?Screenshot (63).pngScreenshot (63).png
Replies (8)
Message 2 of 9
seth.madore
There are a couple things you can do, such as clever use of 2D Contour, or use Horizontal finishing pass. I'm not fond of Horizontal, as it tends to cut one additional pass all around the part, wasting significant time..
Share the file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Message 3 of 9
i'll have to give the 2d contour trick a try. heres the file!
Message 4 of 9
kellings
Here is a file with a couple different ways showing what Seth talked about. I modified your pocket just to do one face, and I added a contour op that does one face with multiple passes. Hopefully these methods help.
If you have any questions as to how I did this, let us know.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 5 of 9
seth.madore
Slow day at the office @kellings ? 😉
Seth Madore
Message 6 of 9
very clever usage of the 2d pocket. i almost never use the stock contours option. forget its even there most of the time. awesome display of how to solve this problem i've been having. will definitely remember that next time.. this time i already did the 2d contours. and got it working right. Now just wish me luck on this job. 12 hours to make 1 of these, seems like alot of time but somehow im almost out of time on this program!
Message 7 of 9
kellings
@seth.madore Nope, just procrastinating haha
Just hoping the other forum we are part of starts to pick up some activity and then started to have a look this forum to see what was happening. It's like a ghost town in there......
Kevin Ellingson
Message 8 of 9
seth, on your screencast, does it work with the smaller face almost centered on the part? it doesnt when i try what you do.
Message 9 of 9
kellings
@CuttingEdgeManufacturing Screen Shot 2019-09-05 at 12.59.38 PM.pngScreen Shot 2019-09-05 at 12.59.38 PM.pngMake sure the red arrow is on the right side of the line you selected as your geometry. I think this is the surface you are talking about in your question.
Kevin Ellingson
