What are these mill bits called and how to add them to my tool library?
Message 1 of 8
Hey, I had these bits given to me, but I have no idea how do I create these specific types in my tool library, because they are pretty extraordinary, I can't seem to find a laser point bit in the tool library, so what do I do to add these in?added a pic below and some links to the specs. Please help!
https://www.cmtorangetools.com/eu-en/industrial-router-bits/laser-point-router-bits-60deg
https://www.tolexo.com/cmt-laser-point-bit-758-002-11-t06czy5050.html
http://m.tungstencarbidecuttingtools.com/sale-10638755d-shape-d-carbide-ball-burr-tool-deburring-han...
Replies (7)
Message 2 of 8
johnswetz1982
Your bottom 2 would just be a "Chamfer mill" type bit and the burr would be either a "ball mill" or a lollipop cutter.
Message 3 of 8
roberthaV8SJH
where can you specify the 90 degree shoulder given that you have the angle for example 60 degrees but if you go deeper then the 90 degree material will also mill away. where can you specify that because if you fill in the champer bit you have no possibility for that. here is a link to the milling bit www.cmtonline.nl/cmt-laser-point-frees-60-graveerfrees-12-7x10x50-8-schacht-8-mm.html
Message 4 of 8
seth.madore
@roberthaV8SJH the tool you linked would be defined as a 60 degree chamfer too, zero tip diameter. Does that answer your question?
Seth Madore
Message 5 of 8
roberthaV8SJH
thanks for the response, no it does not answer completely. if you go deeper then the 90 degree tooth will also remove material. I think I can not fill this in.
I am entering all my tools and it is a mess once bought everywhere and nowhere I am currently running into the fact that I want to enter counter hollow drills they have 2 sizes the hole size for example 8 mm hole a countersink hole of 13 mm I can not find this in the library also the counter bore but not how I enter 2 sizes there of hole diameter and counter hollow diameter do you know how this works? I am a beginner as you can see
Message 6 of 8
programming2C78B
1) You adjust your shoulder length
2) Do you mean a counterbore bit? Set it to be as a Center drill!
Please click "Accept Solution" if what I wrote solved your issue!
Message 7 of 8
andy_woodward66
The first two you can register as engraving bits, I have a number of these in my toolbox but you need to play with the taper angle because it's measured from the center line of the bit, i.e. a 60° V-bit has a taper angle of 30°.
I register the deburring tool as a ball end.
Message 8 of 8
roberthaV8SJH
Thanks for your response I'll get to work on it
