What are the best practices moving from (assembly) design to manufacture?
- Mute
- Permalink
- Report
I am new to fusion360 and working through my first CNC project. I have heard that originally in CAD projects, each part had to be designed in separate files and then later were imported and assembled into an assembly file to error check and visualize, and similarly for manufacturing, there each individual file was imported into a distinct CAM software to define toolpaths and generate the NC code (likewise for simulation etc.). I was under the impression that part of the innovation/power of the Fusion 360 framework is the ability to design and assemble all parts in a single file and essentially put all of the engineering functions into a single program...
With this impression in mind, I designed my project entirely in one file. I took care to create new components and subcomponents as I proceeded and to activate those components as I created the sketches and bodies that would define them I also made use of several user parameters to keep things organized and easily modifiable. My final file is comprised of 2 components, with the first consisting of 2 subcomponents and the second consisting of 7 subcomponents. Each component has various features; importantly, when creating many of these features, for a given component, I leveraged the geometry of various other components. For instance, to make screw holes, that were symmetrical across adjacent components, I made an initial hole, then defined planes from adjacent components, and finally used the mirror command to repeat those screw holes on up to four other components.
I am happy with my final design, and now it is time for CAM. I initially began this in the same file, just changing the workspace from "Design" to "Manufacture". My plan was to toggle the visibility of single components and create setups for each component and each stage of its manufacturing, then proceed to the next component and repeat. The first component went smoothly and I even post-processed it to manufacture the piece on CNC. However, when I moved to the next component (which was orthogonal to the first component) I started to encounter some problems, there was a yellow outline of the component from the first setup even when I was editing the new setup (even when I had toggled all parts of the first setup tree to be invisible) the yellow outline would seemingly randomly become invisible; although I was able to define many aspects of the setup, this made me nervous, and I got to thinking that each setup was modeling the entire machine, tool, and component, and that eventually my file was going to become too large and unwieldy, especially if the yellow outlines persisted. I did a few searches on youtube and forums to troubleshoot but could not really find instances of people moving from a full assembly in "Design" to "Manufacture" as I was doing. So instead, I decided maybe I should save copies of each component from my assembly and create manufacturing setups for each individual part. So saved a copy of the component I had been working on and began working on that individual component, but to my surprise, it was missing features. When I looked at the component in the browser, there were several sketches, construction planes, etc. with the prefix "Reconstructed"; I assume that these were generated when I saved the copy of the component as a result of me referencing the geometry of other components in its design, and likewise, the missing feature is a result this somehow not generating completely.
So I am hoping someone can help explain why I'm encountering these issues so I can fix this project, but more importantly, offer advice on the best practices or personally vetted workflows for the process of moving from assembly design to manufacturing so that I'm able to use Fusion360 like the pros. Thank you!
