- Mute
- Permalink
- Report
I'm finally getting around to testing the rotary axis on our new machine.
The machine is a legacy woodworking Maverick (https://lwmcnc.com/cnc-mills/maverick-4-x8/) and uses Mach3. I've been using the Mach3mill post processor for everything that is 3 axis without any problems.
So I'm now testing a part that uses the turning center of the machine, and it seems to work in that the A axis was turning with the spindle, except the spindle was working on the total opposite end of where the 0 offset of the turning center is actually located.
So I'm assuming it's a coordinate problem in my setup.
This is illustrates it:
This is the wcs I set up, which is essentially the same as I would do for the 3 axis parts, except I'm taking the center point rather than the bottom left corner:
It could be a matter of inverting those coordinates but I don't really want to try something without understanding the logic first.
