Wasted motion question
fishtruk
fishtruk
Is there a way to eliminate waste like this?
Isn't there a way other than reselecting everything?
seth.madore
What's the toolpath and selections, can you share your file here?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
fishtruk
Thanks Seth,
It's a 2D pocket with a couple hundred pockets selected. This is not a serious issue since it's a 25 minute operation. The image shows an extreme  - why does it do this - I didn't select them that way.
Some operations have Optimize Order or the like. Why not all operations?
This option would help a great deal as I use tiny cutters for many features and when one breaks, the option of Reverse Cutting Order would help a great deal.
Should I put this in the suggestion box instead?
seth.madore
There are more than a few areas where we could do with some improved control over the ordering (and not just automatic ordering via the software, but true user control)
Seth Madore
programming2C78B
Until then, this is a good part to just use Patterns.
Please click "Accept Solution" if what I wrote solved your issue!
