Warning: Work offset has not been specified. Using G54 as WCS. Why?
boyd.sofield
Message 1 of 19
boyd.sofield
I have been through my work several times now I still get this warning. I have set the origin, and done everything I thought I need to but I still get the flag when I post it to code.
Can someone tell me what I have done wrong?
Replies (18)
Message 2 of 19
boopathi.sivakumar
Hi @boyd.sofield
You always needs to set 1 if the offset is G54
if you set to 0 it also gives G54 in the nc output but it will give warning.
Boopathi Sivakumar
Principal Technology Consultant
Message 3 of 19
boyd.sofield
Hi. Thankyou. I just found that also.
I am wondering why it defaults (the zero) to something that would give me a yellow flag.
Many thanks.
Message 4 of 19
boopathi.sivakumar
you can set to default if you want
Right Click in the tab >Make all default
Boopathi Sivakumar
Message 5 of 19
boyd.sofield
Hello. Many thanks for your reply. It solved the issue with the error.
Unfortunately and it took a wee while to work out what was going wrong. I thought this was a hardware problem, but changing the WCS offset, and pushing that zero to 2, causes my machine to lose its own WCS.
If I zero my machine, the part appears in the wrong location. I have attached a screenshot of Mach 3. Where this is setup, the part, should be just above and too the right of the tool.  Instead, the machine thinks the workpiece is further up the table and too the right.
Have I described this problem correctly? Now if I set the machine WCS offset too 0, this problem is fixed, but I get the error message again. I dont know what too do. I am also planning on machining multiple parts at some stage where this will be required. But this is where I am at for now.
Please advise with thanks in advance. Boyd
Message 6 of 19
boyd.sofield
Apologies, I uploaded a different capture. The machine is up the Y too the RH. It thinks the part is back too the LH of the table. I am sure you will understand.
Message 7 of 19
to3dornottobe
The 'Make all default' option has evaporated for this workoffset, now you are set with 'make user default'. Once set to 1 it still uses 0 as a default value, completely ignoring the 'make user default' input.
So long story short, you have to change it manually to 1 every single time you post. (the value that will be used 9999 out of 10000 times)
Is there a way to hard code this to 1 instead of 0?  (or change it by default to 1 since 0 is wrong anyway)?
Message 8 of 19
seth.madore
The lack of setting User Defaults in regards to Work Offsets is a known (and logged) bug. We are investigating the cause and possible solutions. CAM-30340 for reference
Seth Madore
Message 9 of 19
to3dornottobe
Thank you very much Seth. Good to hear it's on the radar.
Message 10 of 19
boyd.sofield
Being the OP I  see  this is one of my first posts.  Not understanding different work offsets was mostly my problem with an error thrown in
Thanks for the help
Message 11 of 19
to3dornottobe
The issue that is occuring now depends on the new CAM post feature. It shows an error in the NC list that no work offset has been selected and the following error is that the default saved one is not saved at all.
In my opinion, it should be set to G54 by default, unless specified differently, since G54 is the default workpiece offset.
Message 12 of 19
to3dornottobe
This does NOT work.
Message 13 of 19
to3dornottobe
Any news? With the new layout of posting, the problem arrises more prominent as an error (and a fault in F360).
It's not working at all. You can't store your user defaults. It simple changes the user default back to 0 instead of 1. (G54, the most main stream and worldwide most default used setting)
Message 14 of 19
seth.madore
No progress to report. It's been logged, and it's going to be worked on at some point. I don't have a date to share, or a workaround to offer. The only solution is to intentionally specify a work offset at the time of creating a Setup
Seth Madore
Message 15 of 19
lukewNC5YV
Community Visitor
Community Visitor
This warning keeps popping up on mine as well. But the WCS is at 54 and will not let me set it lower? I'm very new to CNCing so am struggling to solve this?
Message 16 of 19
seth.madore
In the Setup, you need to set it to ! for it to register a value of 54 in the actual program. This is counter-intuitive, but this is to allow for the various WCS methods. Some machines, such as Fadal and Okuma (I think), use E1, E2 for offsets, other machines use G54, 55 etc.
1, 2, 3 etc = G54, G55, G56 etc
Seth Madore
Message 17 of 19
to3dornottobe
That's perfect, but it still doesn't explain why you can't set a user default (bug is known for about 6 months now).
I think it should be covered in the post processor of that machine, since Fanuc uses G54, 55 etc, but every offset is defined as 1,2,3in the manufacture environment (and somewhere translated in g54, 55 etc) . Sorry, but this 'feature' is frustrating me for such a long time. Autodesk just needs to address the issue with this limping bug. Or remove the option to 'set it as a user default' of it's too hard to figure out why it doesn't work.
Message 18 of 19
seth.madore
There's a fix for the "Set as User Default" bug, it will make it's way into the product at some point
Seth Madore
Message 19 of 19
wdetig
Thanks, sometimes it's so easy😀
