Warning: Invalid home position moved to closest valid position.
dpar15
dpar15
How do I fix this?
http://a360.co/1PdpyEr
Be as humble as your skills require you be.
dpar15
Nobody has a fix for this? I've done other boring programs and not had this problem. I have to manually edit the program so there is no crash.
Steinwerks
I took a look, but don't do much turning (or really at all yet) and didn't really come up with a solution. I got the "Invalid home position" error to go away but the back of the toolholder crashing into the workpiece got worse, so I don't consider it a solution.
I would email your file to support, as it might be a bug.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Lonnie.Cady
That problem occurs when there is a blind bore.  You can see from the attached it work correctly with a thru hole.  It has been brought up before but not sure they ever addressed it.
dpar15
Seems like a simple thing for them to fix.
Lonnie.Cady
It may take years for them to figure this out.  You never really know.  I have not seen anyone address it from development so I am assuming it is a bug, but maybe they have a different method in mind.
