Visibility of a toolpath
TomaszAdamF
TomaszAdamF
We have new functionality - toolpath visibility. Cool but ...
E.g. I have two setups for the same detail. There are 25 paths in each setup. Until now, when one setup was active, only the paths from that setup were visible. Clicking on another setup displayed the paths for that setup only.
Do I have to enable or disable each toolpath separately in the setup that I want to see? It takes a lot of time! There must be some way to quickly turn on and off the visibility of all paths in a particular setup or tool.
TomaszAdamF
Over 700 views and no response. 😞
Could someone confirm that the problem I described actually does exist? Maybe it's a problem with my computer or installation? After all, everyone who uses CAM in Fusion had to notice it.
If we all have this problem, I will report it as a mistake that makes work very difficult. If only I have a problem, I will look for the reason on my computer.
seth.madore
I'm not sure what you are referring to when you say a problem has been introduced in this update. Can you expand a bit more?
The added (optional) behavior is the highlighting, which just gives a quick view on hover. The added "eyeball" is if you wish to persist display of the toolpaths.
Seth Madore
TomaszAdamF
"view on hover"?  Now everything is clear. I didn't find the word hover in the description visibility of a toolpath.
Thanks. 🙂
