V-carve on curved surfaces?
Sandflo
Message 1 of 31
Sandflo
Hi
Nice november update, been waiting for the engrave toolpath 😉
But is there a workaround to get the v carve to follow a curved surface? For example if you have som text in a big sphere or something?
Thank you in advance!
__________________
Gigabyte P35 V3 , Windows 8.1, Sweden
Replies (30)
Message 2 of 31
jeff.walters
Before we can engrave on an arc we will first need 4 axis continuous cutting, and I'm not 100% sure but I don’t know of a way to wrap text on the round
Jeff Walters
Senior Support Engineer, CAM
Message 3 of 31
dave.anderson
I checked with the Fusion Support guys and there's no command currently available to wrap text on a face or place it on a path along a curve.
Dave Anderson
Sr. Support Engineer– CAM
Message 4 of 31
HughesTooling
Project onto surface seems to work OK!
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 31
jeff.walters
can you cut into the part now?
Jeff Walters
Message 6 of 31
HughesTooling
Not with V-Carve it just flattens the curves to the height settings. My post was more about the statement that "there's no command currently available to wrap text on a face". I have a plug-in for Rhino that does V-Carving with 3d lines like the one's in my post. It's not really any different to 2d curves in that it maintains 2 or 3 point contact, similar to pencil machining.
Mark.
Mark Hughes
Message 7 of 31
scottmoyse
You can get a result using the Pencil strategy. It will pull up in the corners on curved surfaces. Just make sure the tip radius of our chamfer tool isn't 0. The smaller it is, the longer it will take to generate.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 8 of 31
kellings
There is currently no emboss/engrave command to create text on a cylindrical face, but you can replicate the emboss/engrave command (about 95% of it) using a couple of different methods.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 9 of 31
Sandflo
Thank you everyone for your answers.
Its what Hughestooling descripes, that is what i mean, it doesnt need to me a wrap, just a text on a curved surface, just not 2d.
Could someone give me an example on how to use the pencil path to have the same result, but on 3d surface?
Thank you once again.
But am really waiting for the wraping fuktion
__________________
Message 10 of 31
HughesTooling
After thinking about this and Jeff's post above I realized you are talking about wrapping the text around a shape rather than projecting. For wrapped text you do need 4/5axis and at the moment there is no way to wrap curves around a surface in Fusion. What I'm after for mould making is projected curves, engraving with 4 axis could produce undercuts that would not eject form a mould.
Here's an example where the text is projected and machined with on 3 axis, it would be nice if the new Engrave op could use the 3d curves as I think it would calculate faster then using Pencil on a 3d model.
Mark
Mark Hughes
Message 11 of 31
HughesTooling
Hi @Sandflo
Here's an example fsd using pencil.
Mark
Mark Hughes
Message 12 of 31
scottmoyse
@HughesTooling wrote:
Hi @Sandflo
Mark
You beat me to it. Nice work.
Scott Moyse
Message 13 of 31
Sandflo
@HughesTooling
Thank you, ive tried on my own now and figured it out, but it takes a while to calculate 😉
Please see attached
__________________
Message 14 of 31
scottmoyse
The key to speeding it up is increasing the tip diameter to the largest value to can get away with. At least it does the job, albeit slower than ideal.
Scott Moyse
Message 15 of 31
Laurens-3DTechDraw
Indeed.
Making the tolerance a little looser might help as well. I mean your engraving can most of the time handle 0.025 mm instead of the default 0.01mm tolerance.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 16 of 31
Sandflo
Has something cahnge with the pencil operation?
I cant get it to work anymore?
If i regenerate the example the hughestolling have made it doesnt show the same?
Is something changed in a new update?
Can someone else please try?
Tiday was the day that a was going to mill it in the machine, and it doesnt work
__________________
Message 17 of 31
HughesTooling
It looks like they've changed it so it will only work with a taper mill not a chamfer cutter. File attached.
Mark
Mark Hughes
Message 18 of 31
Sandflo
thanks again hughes.
It works now again, wonder what the changed and why?
__________________
Message 19 of 31
scottmoyse
I think that's a bug to be honest. I shouldn't have changed and breaks backwards compatibility which they never want too do
Scott Moyse
Message 20 of 31
Laurens-3DTechDraw
Indeed Scott.
I've seen people post that the 2D chamfer now also only takes tapered mills so I think the wrong button was pushed somewhere.
Laurens Wijnschenk
3DTechDraw
