Using fusion 360 manufacture tools to CNC rout Aluminum Composite Material
ALE.REAL3D
ALE.REAL3D
My name is Alejandro Gonzalez
Thanks in advance for any advice you may help me with
I am fairly new creating tool paths for the CNC router
and to make it better I am trying to cut ACM (Aluminum Composite Material ) in which a 90 degrees V tool with .090 flat tip goes into the material leaving only like .015" above the bottom.
The problem that I am having is that no matter how I want the groove to be centered with the bending centerline of the flat pattern or with a  line created in the Manufacture Model environment as a sketch the tool is moved to the left of the line.
I am using a 2D Contour strategy
On the Passes tab, I have tolerance = .0004
Sideways compensation: left
Compensation Type = off
Compensation radius allowance= .01965
and that's basically what I have
And the toolpath simulation shows the tool to a side of the line
never on top exactly
I am attaching a model in which you can see that I moved the line (open contour  (and maybe that's the real problem here)) to make sure that the cut is on the center of a line that goes between vertices (imaginary line )
Please advise
johnswetz1982
Use [Trace] operation instead.
ALE.REAL3D
 Hello there
When trying to cut the Aluminum Composite leaving only around .75 mm from the bottom to be able to cut the first layer of aluminum and some of the inside polypropylene to bend the material this is the message I got:
"The Safe Distance is higher than the Feed Height. Consider reducing the Safe Distance, otherwise, the Feed Height will be raised to match the Safe Distance"
I really can't find a way to avoid this message
Any help will be very apperciated
seth.madore
It's honestly not something I'd worry about, as it will have zero impact on your toolpath creation. If you're bound and determined to eliminate all errors and warnings, take a look at the Height Settings of Clearance, Retract and Top Heights. Now take a look at your Safe Distance. If your Retract plus Top Height exceed your Safe Distance, there's your issue
Seth Madore
ALE.REAL3D
Thanks a lot for this answer:
It will solve the problem of the tool alignment with the model lines
I will have to fight with the sheet metal environment to create a material that can give me the bending conditions of the Aluminum Composite in order to get a flat pattern that can be used with the trace toolpath. ( and I will  !!) Maybe using a very thin material with a specific bending radius and
Another question Is the Axial Stock to Leave on the stock to leave tab the only way to determine the depth of the tip of the cutting tool into the material ?         since there is not modeled v groove in the model?
Big Thanks
johnswetz1982
Axial stock to leave, or you can do [Model Bottom] and then give a positive number that will raise your tool above your table/face of material.
ALE.REAL3D
Thanks a lot for all the answers I got here in the forum
It is  still non an intuitive way to create these elements using the sheet metal environment I will definitely keep trying and once I have a good approach I will post it
Thanks again to all
