Using Fusion 360 as a cam package for nested layered DXFs - Advice before purchasing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Looking for some advice to see if Fusion 360 can do what we want it to do before purchasing, we are a bespoke cabinetry shop and are looking at getting a new CAM package as an upgrade from Vectric V-Carve.
We design nearly all of our projects in Polyboard (a specific cabinetry CAD package) , export and nest them in Optinest. From here we export each sheet of nested parts as a layered DXF. Each of the layers needs a separate operation doing to them (profile cuts, pockets, drills etc) and is named accordingly. We currently design other projects in Solidworks.
Almost all (I can think of 2 projects in 4 years that arnt) of our projects use 2.5 axis cutting on sheet wood materials, usually 8x4 sheet size. Although our machine is capable of cutting 10x5 sheets.
A typical sheet will look something like the image below...
Would it be possible to import these nested DXFs into fusion 360 and just use the CAM features? We want to find a way to semi automate the process as a typical project may use 15-30 sheets so want the process to be as smooth as possible.
Can anyone advise? Happy to send over a sample nested DXF file if it will help.
