using cut to cut a hole in a pocket
leoE4H8W
leoE4H8W
I extrude a pocket and added a cut for a hole, but simulation isn't cutting the hole
programming2C78B
Ok...you need to give us something to work with
Please click "Accept Solution" if what I wrote solved your issue!
seth.madore
@leoE4H8W Are you asking about a Design or Manufacturing issue? Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
leoE4H8W
Here's the file
marcus.toepke
Your pocket size minus your Stock to Leave is to small for your tool diameter!
Without or smaller Stocl to Leave it works
leoE4H8W
Thanks you, that worked
