Update Bug 3D Scallop
bmxjeff
bmxjeff
Love the update, awesome stuff.
First bug I've seen so far is Updating the model then attempting to edit the 3D Scallop op associated to it.  Fusion freezes.
My work around will be to Dis-associate the Op, then make the model change. Right now, it fails everytime.
Jeff Hooper (Owner)
Hooper Machine and Design
[X] AUTODESK AMATUR ORDINARY
bmxjeff
There is definitely a bug when editing the model then going back to CAM.
1. The Operations do not go out of date when a model change is made.  - So, It Re-Generates correctly, but does NOT warn you that the model changed.
2. 2D Contour Does NOT update to a Model change. Even after a Regeneration of the toolpath. The only work around to this, is made a new Contour. Deselecting the Geo, and selecting it again Does NOT fix it.
It seems that the problem is mostly around 2D selected contours, whether a boundary or toolpath.
Jeff Hooper (Owner)
xander.luciano
Hey, thanks for reporting this!
I can't reproduce this on my end, can you send the file you're working on and the edits you make that aren't invalidating the toolpath correctly? Maybe even a screencast also if you can. I'd like to get this logged and looked at by a developer.
Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
bmxjeff
@xander.luciano  Hey man! Am I seeing you next week?
I didn't get it to repeat on another file, new or legacy. That's good. But, it is happening here. Just so happens on the Only project I've worked on since the update.
The project is attached. I'll try to figure out the pattern. Thanks,
Jeff Hooper (Owner)
xander.luciano
YES YOU WILL! - but you know that already haha.
Well, glad you managed to stop breaking the software haha! But if it creeps up again, let me know please. I've seen other issues with geometry being dropped that I've been keeping an eye out of and trying to track down, but have never been able to figure out a reproducible workflow. Hopefully it's been fixed though!
Thanks Jeff!
-Xander Luciano
Xander Luciano
