- Mute
- Permalink
- Report
In the attached file I am unable to select the outside of the gears unless I select every small segment (300 segments - not likely). Selecting the interior ovals works by selecting the outline but the same does not happen for the outside gears. I also cannot select the face - I am assuming because there are cutouts? (But I can select the face when not in the 2D Contour selection mode??) I have selected a few of the outside gear segments to show what I can select. "[T6] 2D Contour5" - generates a warning and does not create a tool path.
I could create a sketch in the manufactoring space and project the gear onto the sketch and then select the sketch. This makes a very large sketch which I want to avoid. This is one gear of a six gear project so would be a lot of sketch elements - not the most efficient way to model.
Is there another way to select either the face or the exterior of the gear - all the teeth in one selection?
Thank you for any ideas/ solutions.
Doug
