- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Everyone,
I have been encountering inconsistent problems with the Fusion NC Programs dialog box for a month or two now, and I thought I would try to get some help with the issues. Occasionally, when I try to edit an existing NC program or create a new one, the dialog box either does not come up, or comes up as greyed out and cannot be edited. When this happens the other NC programs/operations/toolpaths in the file become unselectable (in the case of the greyed out box, they are unselectable after I exit the dialog box.) Fusion also becomes less stable when the glitch is active and tends to crash, especially if I close the file and try to reopen it. I haven’t been able to find a consistent way to reset the glitch, and it stops me from posting code, which is very frustrating. I have tried the following with no consistent success.
- closing and opening the troublesome file
- closing and reopening fusion
- logging out and back into fusion
- restarting my computer
- uninstalling and reinstalling fusion
- repairing fusion with the new utility dialog
- Running the network diagnostics in the new utility dialog while the glitch was active (all appeared good)
- Making edits to the setup/models/toolpaths to reset whatever causes the glitch
- Bringing my personal laptop to work and testing with that, ran into the exact same issue on both computers after the update to v2.0.12665.
The glitch has occurred across 7-10 files on different days. In each case it fixes itself eventually, and generally seems more frequent the first few times I try to post code after fusion is updated. I have never encountered it when I am using fusion at home, but that might just be because I use it much more frequently at work. (Note I use the same laptop at home that I mentioned in my last bullet point.)
I am using a highly modified Fadal post processor, but I don’t think that’s the issue because the glitches are inconsistent despite constant use of this post. This post is attached, a word doc which I have recorded some of the glitches in with my attempted solutions, and the diagnostic logs folder. The most recent file which gave me trouble is shared by the link below. Note that the way I have done my stock/model/wcs in this file is consisted with the other files which have given me trouble. Hopefully someone will have some ideas!
Thanks for the help!
Sincerely,
Matthew
