Unable to delete/remove tool libraries
FrodoLoggins
Advisor Advisor
FrodoLoggins
I'd like "Tools" and "Tool Holders" to be removed:
I'm unable to right click on them and I've tried deleting the assets from within Fusion drive but I can't see them anywhere. I've also tried logging in/out.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
Chetan.Bankar
Hi @FrodoLoggins,
Thanks for raising your query onto forum.
The cloud tool library are stored inside of a Fusion 360 users cloud data called Assets which can be seen by going to Data Panel >> Libraries >> Assets >> CAMTools folder.
If you are unable to see your required tool library in the Assets folder, then I will suggest you to try login onto your Autodesk 360 account and see whether you are able to see it under Assets >> CAMTools. If yes, and you wish to delete the complete library then you can select it and delete it from your account.
I hope this helps. If you are still facing the problem then let us know whether you are on Fusion 360 personal myhub or Team hub?
Thanks and Regards,
Chetan Bankar
Global Product Support
Submitting & Viewing Support Requests | Web Support | Phone Support
seth.madore
Hm. I'm not seeing this issue on my Mac. I can right click on any Cloud Asset and delete it. Any chance you could make a ScreenCast of your actions and the computer behavior?
Seth Madore
FrodoLoggins
Hi thanks for the reply. I'm unable to see the two assets from either within Fusion or after logging in online. I can only see them from within the tool library window inside Fusion. I must have deleted them a while ago and some temp file is still hanging around.
As you can see from the screencast, from within Fusion's libbrary window, I'm not able to right click and hit delete like I am other libraries.
https://autode.sk/2HkqNEu
FrodoLoggins
Here you go!
jeff.pek
If you open the Finder, and navigate to ~/Library/Application Support/Autodesk/Autodesk Fusion 360/<userid>/W.Login/M/<another id>/CAMTools, do you see files there with the names that are showing up (but are non-deletable)? You could try just deleting those, presuming that you don't want them.
Separately, in the left-hand side panel, in the "Assets" project, under "CAMTools" folder, what do you see in that folder?
Jeff
FrodoLoggins
I did a search in:
and deleted every reference.
Thank you!
