Tutorial on WCS Probing and 4th Axis Wrapping [Intermediate]
xander.luciano
Alumni Alumni
xander.luciano
Hey Guys!
Mike Mattera did some great videos on all the new features in Fusion Ultimate (links available on the what's new post) and I wanted to follow up with some intermediate level tutorials for some of the more seasoned users.
WCS Probing:
4th Axis Wrapping:
I'll be keeping an eye out for questions about the new features, but I expect an influx of posts here, so if I miss a question please tag me and I'll work on getting out answers as quick as I can.
Thanks guys! Hope you enjoy the new features 🙂
-Xander Luciano
Xander Luciano
CAM Content Developer
If my post is helpful, press the Kudo button - If it resolves your issue, press Accept as Solution!
Quick Tips: When to resselect CAM geometry | Understanding Smoothing in CAM | Adaptive Facing | Online GCode Viewer
Stuart-H
Hi
would it be possible, or a link to a vidieos , for a walk though on how to use the 4 th axis e.g. I had a part to make for my corliss mill engine  model which in volved a slow helix around a 18mm shaft 90 degrees in 37 mm 3mm wide ,hope that makes sense this was a month or so ago in the end I hand coded it as G1 A90 X37 F25 note my mill is in metric mode by default
a short walk though would help as it would get users off on the right foot and not start with bad habits as I did with the CAD side of things
Stuart
Mac Studio M1Max and MacBook Pro M1
daniel_lyall
@xander.luciano What did I say, I knew it. LOL
@Stuart-H Hi Stuart can you post the model it would make it easier for someone to show you what to do, there are a couple of 4th axis videos on my channel that may help.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Stuart-H
at this time I have no model but will have soon when i do the cams ( as in lumpy things ) not CAM
as i said  i hand coded the helix i needed
I certainly will look at your channel thanks
Thanks again for your time
Stuart
