Turning - milling
Turning - milling
Message 1 of 14
Turning - milling
How make a turning milling operation ?
Thank you
Remy
Replies (13)
Message 2 of 14
scottmoyse
You can purchase CAM training from your local CAM Reseller. Or figure it out by yourself from all the YouTube videos on the subject and built in tutorials.
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 3 of 14
Lonnie.Cady
Problem with that advice @scottmoyse is that there are not really any good turing turtoials or youtube videos.
@Anonymous  Can you post a file?  Are you just want to add milling operations to a turning job?
Message 4 of 14
scottmoyse
I'll do one in my own time. But I was simply illustrating nothing is free and that the best approach would likely be to seek out some training. Sent from my Windows Phone
Scott Moyse
Message 5 of 14
Lonnie.Cady
Sure there is @scottmoyse, help here on the forum is free.  At least I have never paid for it.Smiley Happy
That is the purpose of these forums, to get help from other useres.  Jeff is an ADSK employee and helps here a lot.
Message 6 of 14
scottmoyse
No its not. Time = Money. Also typically support from Autodesk employees on these forums is only for customers on subscription. That will be another reason for them to migrate the old forums to Lithium... Because there is automation in place for Autodesk Subscription customers. Sent from my Windows Phone
Scott Moyse
Message 7 of 14
scottmoyse
Right, now I have a moment I can reply properly.
Here are all the technically rock solid YouTube channels:
Autodesk CAM
HSMWorks
CAD / CAM Australia & New Zealand
NexGenCAM
P9 CAM Solutions
Mill Turn from a programming standpoint is combining the turning toolpaths with the milling toolpaths. You just need to program the milling aspects positionally. So look for 3 + 2 programming videos in that lot. HSMWorks is a different UI, and has slightly different selection techniques but the principles are the same. Basically you need to set tool orientation in the geometry tab for each milling/drilling operation.
Time is Money. If you are running a business, and you want to spend time with your family in the evenings, then the quickest way to learn is to pay for training. These forums aren't a training resource, but are a learning resource. If you have time to burn, and don't mind a slower learning path, then get stuck into the supplied tutorials and the various YouTube content.
NYC CNC is also a good YouTube channel for Fusion 360, but he's learning on the go, so sometimes shares bad technique or uses uneccessary workarounds. He hasn't done any mill/turn yet though.
Once you get started yourself, and show us some examples of what you are trying to achieve, and where you have got to, then we can help out much easier. Just asking how to do mill turn is a broad question, and doesn't demonstrate to anyone what you have tried to achieve by yourself already.
Scott Moyse
Message 8 of 14
daniel_lyall
for doing 3 + 2 tool paths the fusion tutorial is fine all you have to do is make sure you set the origin to middle end (ever end) on all tool path's, to set the rotation you just click on the face you wont to cut, if that is not enough you can just add a hex or how many sided what ever to the end to give more rotation's you add this as a body not attached to the model you wont to cut.
if you wont more info on this just ask, for the turning bit look on the HSM forum there is some info there what will help.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 9 of 14
daniel_lyall
well that will be a very bad move for AD to do that, any newbe testing out fusion getting no suport = no what scott
Daniel Lyall
The Big Boss
Mach3 User
Message 10 of 14
scottmoyse
Fusion isn't typical... I used that word deliberately. Autodesk don't normally support any of their products during 30 day trials. Fusion is the exception. So are the Xpress CAM products.
Scott Moyse
Message 11 of 14
daniel_lyall
that's daft
Daniel Lyall
The Big Boss
Mach3 User
Message 12 of 14
scottmoyse
@daniel_lyall wrote:
that's daft
Not really. If a 17 year old went to a car dealer and said I'm interested in buying a car, but can you teach me to drive during the test drive. What would they say?
At least with software you get a whole bunch of tutorials to guide you through the process.
There aren't any mill / turn tutorials in the product yet, there should be. And I'm sure there will be soon.
Scott Moyse
Message 13 of 14
scottmoyse
In any case... this video shows Tool Orientation in Fusion 360 on a mill / turn part.
Scott Moyse
Message 14 of 14
daniel_lyall
that's daft
OK that make's sense
Daniel Lyall
The Big Boss
Mach3 User
