Turning Canned Cycles and Fusion?
LibertyMachine
Mentor Mentor
Message 1 of 65
LibertyMachine
After a bunch of searching on this forum as well as the Post Processor forum, I've come to the realization that there isn't much in the way of support for Turning Canned Cycles, such as OD/ID Roughing or Finish canned cycles, threading, grooving so on and so forth.
Question is this: Is this a function of the Fusion software, or is it current limitations of the Post Processor?
If it is software, where does it land on the development roadmap?
While I do not currently own a CNC lathe, I was trying to get some code out for my employer (day job) and I ran into that unexpected limitation.
Comments from the developers?
Side note: if one was to buy an older used CNC lathe, the memory capacity could very quickly be absorbed by a program of medium complexity, assuming more than a few tools. Yeah yeah yeah...drip feed.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Replies (64)
Message 41 of 65
akash.kamoolkar
@Anonymous
We have finished implementing the G71 / G72 canned cycles and they will be released to customers with the new profile turning strategies in an upcoming release.
Akash Kamoolkar
Akash Kamoolkar
Software Development Manager
Message 42 of 65
scottmoyse
awesome sauce
Kind Regards
Scott Moyse
Manufacturing Technical Specialist Autodesk Expert Elite
P: +64 9 302 4028 M: +64 21 055 7775
[email protected]
CADPRO Systems Ltd
Auckland - 527b Rosebank Road, Avondale Auckland
Christchurch - Unit 3, Kendal Avenue, Burnside
New Zealand
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Message 43 of 65
dmartinS68QJ
Looking forward to this functionality.
-Dan
Message 44 of 65
andrew.todd1
This is great news. Game changing.
Message 45 of 65
andrew.todd1
There has been an update today but this feature is not there. any idea when we can expect to see this?
Message 46 of 65
seth.madore
The update that rolled out a couple days ago was a hotfix to address a serious issue that was found in the Manufacture environment. The canned cycles will be coming "soon" 😉
Seth Madore
Message 47 of 65
You need to change turners 🤣
Message 48 of 65
randyT9V9C
@seth.madore per usual I'm a slow adopter. Today I decided to update my post processor to support G71 and G72. Looks pretty good. It shrank my sample roughing operation from 4.2K to 0.48K! Almost one tenth the size isn't bad. This will prove very handy on the old 0T-A. Even after maxing out the memory is only has a whopping 48K.
Any word on G70 finishing?
Message 49 of 65
randyT9V9C
For a proof of concept, it was fairly trivial to add same tool G70 finishing to the post processor. I simply stored the P and Q values and used them to appended a G70 call following the roughing. It's not ideal in that it's using the same tool as roughing AND finishes at the roughing feed rate. I worked around the feed rate issue by hard coding a value to the first block in the path which G71/G72 ignores. This works for testing. If anyone is interested I can post my code and maybe sharper eyes will find a better way.
I posted the G70 canned cycle request to the ideastation.
https://forums.autodesk.com/t5/fusion-360-ideastation/fanuc-g70-finishing-canned-cycle/idi-p/9174051
Message 50 of 65
At this point, G71 and G72 cycles don't produce cutter compensation so following with G70 does no good.
The only way to do it is to make finish profile tool path which does produce in computer compensation and use NC editor to arrange code in G71 / G72 cycles, then follow with G70 with added finish feed rate.
Awkward way to do it but it works if you are OK with using same insert radius for roughing and finishing.
In my last test, using in control compensation with finish profile, tool crashes into face of solid part, not good.
In Fanuc control, when using in control compensation in G71 / G72 compensation is canceled due to retract move that contradicts basic function so G41 and G42 would only be effective in G70 cycle which can overload insert tip on tapers and internal arc moves where roughing tool leaves extra stock on top of given U and W.
Message 51 of 65
randyT9V9C
Thanks @Anonymous, I didn't catch the cutter comp issue. 😉
I was definitely thinking the canned roughing needed to be an option on the finish profile and you've confirmed my  suspicions. I mentioned that in my Ideastation post. Hopefully we'll see the appropriate changes in future releases. For now I'm simply happy to finally have canned roughing.
Message 52 of 65
seth.madore
What we currently have for Canned Cycles is NOT a finished product, but rather, a "Work in Progress". The approach that the dev team has is "Start with the basics, build on it from there as needed".
Seth Madore
Message 53 of 65
Well that's most important thing g41 and g42 is pointless.g71 g72 g73 ignore it so it means every downward slopes will cut too much!!!.you need calculate figure without compensation.means you calculate correct path no g42.it also mean you can use same path for finishing..if finish tool has same more radius.i not use cam or g42.i calculate all paths with TNC because its easy.and if machine support type 2 g71 that's god bless.only need figure and machine turn pockets.g70 can be use u1 so it still leave stock and then do another g70 u0
Secret formula that cam software developers don't want you know.
(1-TAN(a/2)×TNR=z nose compensation correction.then TAN(a)×length z =x radius offset so multiply it can get starting diameter..
Message 54 of 65
My point was that canned cycle at this time don't produce in computer calculated cutter compensation.
The way around it is to use finish profile tool path which does produce cutter compensation and plug that G-code into canned cycle via NC editor copy / paste function.
Canned cycles do exist now with noted bugs but one can avoid 10 pages of long hand code on large parts by using few extra key strokes, speaking of which, same option was there before introduction of canned cycles in Fusion.
You would simply produce two finish passes using same or different TNR and edit code to turn one of them into canned cycle.
For people who don't know how canned cycles work, there is now "Use canned cycle" check box in Fusion,... with few hiccup's but it's a progress.
There are very good reasons why in control cutter compensation has been largely abandoned by shops, there is better way.
Message 55 of 65
akash.kamoolkar
@randyT9V9C
The plan is to add G70 to the finishing operation and to associate roughing and finishing operations so when you turn on G70 it will automatically know to use the P and Q values from the G71 / G72 roughing canned cycle.
Akash Kamoolkar
Akash Kamoolkar
Message 56 of 65
CNC_Lee
@akash.kamoolkar Any updates on this?
Thank you
If my post answers your question, please use Accept as Solution.
CNC Lee
Autodesk CAM Post Processor Expert
Message 57 of 65
akash.kamoolkar
@CNC_Lee We are actively working on adding the G70 canned cycle finishing pass to G71 / G72 output. Hopefully if everything goes as planned it should be available in an upcoming release.
Akash Kamoolkar
Akash Kamoolkar
Message 58 of 65
Trent8Z6EP
Any update on this?
Message 59 of 65
akash.kamoolkar
@Trent8Z6EP Unfortunately due to circumstances this feature has been delayed and there isn't an ETA on it at this point.
Akash Kamoolkar
Akash Kamoolkar
Message 60 of 65
doughertykris6
Community Visitor
Community Visitor
@akash.kamoolkar @Still nothing?
