trouble with sheet metal
brockdwelds
Message 1 of 8
brockdwelds
I have been trying to put relief slots along all the bend points but can not for the life of me figure out how. I have made slots that would appear but when I went to set up a 2d profile to set up the tool path, it would not let me cut from inside out. this resulted in leaveing ugly cuts for lead in and lead out cuts. is there a easy way to add cuts along the bend points?
Replies (7)
Message 2 of 8
engineguy
@brockdwelds
Would help a lot if you can upload your Fusion file, makes it a easier to see what is going on 🙂
Go to File>Export>Select f3d format>save to a location on your computer>then attach it to your reply.
Stay Safe
Regards
Rob
Message 3 of 8
brockdwelds
here is the project
Message 4 of 8
daniel_lyall
You need toolpaths in the example you post so we can see where you are going wrong.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 5 of 8
brockdwelds
my bad
Message 6 of 8
carl.j.barker
I usually don't draw the full slot, just a center line then use center compensation and no lead in/out to do chain cuts.
I tried running your tool path after changing the tool to the laser tool I use and all was good. So it's looking like your slots are too narrow for the 1.8mm tool you chose.
Here is your design using center lines for the slots, which seams to  work ok (only done 1 line just to show).
Message 7 of 8
ChristopherMarion
@carl.j.barker
I just went through the same solution for him in another thread.  Great minds think alike I guess 😁
https://forums.autodesk.com/t5/fusion-360-manufacture/problems-with-toolpath-for-2d-cutting/td-p/980...
Have a good weekend guys!
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
Message 8 of 8
brockdwelds
Thank you !!! 2 tool paths was the way to go. I didn't even think that was an option.
