Trouble Engraving very Small details
MarkDGaal
MarkDGaal
I’m having a bit of an issue with getting either Fusion 360 or CarbideCreate to V - carve some very fine lines of a logo.
Logo looks like this:
I’m trying to V-carve all of the detailed/inner features on the olive leaves and waiter’s hands and serving tray… but F360 will only recognize a small % of the line segments… I do get this warning:  Open curves were selected. These will be ignored. However, there isn't much on google about that.
Fusion File:
https://a360.co/34InBAa
I've tired identifying the diameter of the tool tip as 0 as well as playing around with tolerance and angles... but I just can't get F360 to try and do the other line segments in the sketch... any ideas?
Simulations from F360 ignoring a good portion of the sketch:
seth.madore
For the open contours (those are these features here):
You are going to need to use the Trace toolpath, and a fair amount of manual selection. It would almost be better if they were ALL open chains, as you could then just select the sketch from the Browser menu
Seth Madore
seth.madore
Oh, here's the file
Seth Madore
MarkDGaal
Thank you very much... I got her done!
