Toolpaths different when changing tool
cunnc1
cunnc1
Hi guys, new to Fusion and CAM in general and I've really hit a brick wall!
So the part I'm trying to make is a specifically sized washer, OD 51.5mm, ID 14mm.
I originally used MeshCAM V6 to cut the part but with just a circular toolpath in 316 SS I quickly burnt out my favourite HSS end mill.
I figured the reason was that with a curcular toolpath 50% of my endmill was always in contact with the SS.
So I thought it time to knuckle down and learn Fusion360.
I came up with this what I figured would be a perfect toolpath which I've attached below.
I then realised that I still had my old end mill selected.
So I made a new tool, same feedrate, plunge rate etc, just with the new dia.
When it rewrites the toolpath I get back to a circular toolpath which I just cannot for the life of me get back to the one screenshotted.
Any advice would be a MASSIVE help before I outsource these to be lasercut.
Many thanks, Craig
jeff.walters
Did you select the new tool in the operations? It would help a lot if you could post your file so we can see what you have set where.
Jeff Walters
Senior Support Engineer, CAM
cunnc1
Thanks for the reply Jeff.
http://a360.co/1S60Xhs
I hope that is the correct way to share things here.
When I realised I selected the wrong tool, I edited the dia of the selected tool to find it ruined my toolpath. So I undid that then created a new tool and even then I couldn't get my desired toolpath back.
Thanks, Craig
jeff.walters
So are you trying to cut this from sheet stock or disks?
Jeff Walters
cunnc1
It will be cut from sheet. So my thinking being a helical decent into the sheet, then circular motions to clear about 10mm of material around the washer to save burning up more pieces.
I couldn't find much info on milling sheet metal from my searches as I can only assume a lazy cutter would be the best tool for the job.
