toolpath selection
toolpath selection
matthew_pitmanF2EMW
toolpath selection
matthew_pitmanF2EMW
Which would be the best toolpaths to finish the faces and diameters of this part? ive tried numerous paths and cant seem to get it to work. see image and attachments. i have access to the manufacturing extension but the 2nd op is done of 3+2 mill rather than full 5 axis.
programming2C78B
I'd start with Geodesic but am following along to see what Atlas suggests.
Please click "Accept Solution" if what I wrote solved your issue!
a.laasW8M6T
Its definitely do able in 3+2 but some surfaces will need to be attacked from multiple angles and you will need a 1mm ball nose to do them.
Unfortunately I don't have time atm to come up with the toolpaths and I'm going to be away for a week but yea you can do parts with Advanced swarf set to 3 axis, parts with Blend  and the 8mm endmill, rest with geodesic  and multiple positions.
Andrew Laas
Senior Machinist, Scott Automation
matthew_pitmanF2EMW
okay thank, ill have a look.
