Toolpath Memory Query
kretallick144
kretallick144
Having an issue with the amount of memory used for a tool path.
In Fusion It says 18.1Kb   When saved ready to go to the machine it is 385Kb.
It is a Bore path with a stepover,  repeated 8 times.
Please explain?
seth.madore
What post processor are you using, and can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
kretallick144
Hi Seth,
Im using the Robodrill processor.
I have somewhat sorted it out.    Allowing 3D arcs reduced the Kb to the same as the Manufacture .
With only 128Kb of machine memory i have to be careful.
