Toolpath is scaling my Y axis?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am moving to Fusion after years of running my school's CNC router on RhinoCam.
When I post a toolpath generated in Fusion, my Y-axis appears to be getting scaled down. I posted the same toolpath using RhinoCam. All three axes are correct, so I know it isn't about retuning the axis motors.
I can try to add G51 code to adjust the scaling, but I'd like to find a more elegant solution.
Is there a setting somewhere that I may have changed the toolpath scaling? I am new to Fusion, so I worry I missed or didn't understand some setting. The scaling does not appear in my drawing.
One test toolpath I used was a simple 2"x2" square. Going over the g-code, it was outputting moves that should have resulted in this shape- the math checks out.
Further background: The CNC is old, and is currently being run from Mach3 with some hardware changes internally. It is a Precix (which I do not recommend), I have used the machine builder to make a digital twin of my machine, and that is the one specified in my setup. I have also modded the post processor to set custom default settings (to make it easier and safer for students to use).
Thanks for any leads-
Graham
