Toolpath edit panel dissappeared
afrith
afrith
I went  to edit a tool path and the usual panel came up which was ok. Unfortunately as I moved this panel upwards towards the toolbar at the top it dissappeared and I cannot seem to get it back meaning I can no longer edit the tool paths. Restarting Fusion did not help so hopefully this is an easy fix.
Thank you
seth.madore
Well that's not good...
I wasn't able to make my menu disappear by moving it up off the screen, but I certainly was by moving it down. However, a Fusion restart cured that and brought it back into view, but that's not working for you?
Seth Madore
afrith
No a restart did not work. I'm going to open it up on another laptop and see if that works.
seth.madore
I'd be curious to see if an uninstall and reinstall would do it. It's relatively quick and painless, just make sure to backup any local libraries you might have.
Seth Madore
afrith
I was about to do the uninstall when upon opening Fusion on the 3rd try the panel was visible again. Quite strange but at least it's back so I can finish my project.
Thank you
