Message 1 of 18
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello, I just finished converting a small 2HP benchtop mill to CNC. My first part on this mill is the Titan 1M (From Titan CNC Acadamy). Here is the good and bad news:
**Operations:**
- Facing - Worked perfectly.
- Adaptive1 - the toolpath that roughs out the contour and pockets - Worked Perfectly.
- 2D Contour - Fusion created a toolpath the was about 3/8" wider and 3/8" taller than the correct size. The tool for this toolpath is a 3/8" end mill. Is there some setting that I may have configured incorrectly to make this happen
- 2D Pocket1 - This toolpath worked correctly but it left a rough bottom surface (see image).
- 2D Chamfer (upper section) - Worked great.
- 2D Chamfer (lower section) - Worked great.
- Drill Spotting: No good. Location of chamfers are in the wrong place.
- Deep Drilling: No good. Location of holes are in the wrong place.
I have uploaded the fusion file and image of the part.
Any help would be greatly appreciated… Richard
