Tool Path Containment
dcpanzone
dcpanzone
Hello there,
Having a bit of trouble with constraining a parallel tool path. I've tried selection for machining boundary, which it mostly follows but intersecting geometry in the model is forcing the path to make an unwanted correction leaving a deviation in the finish. I've tried adding a patch into the model to no avail, I've also attempted to constrain it with Avoid/Touch and Model Faces. Any insight would be helpful.
Thanks!
Marco.Takx
Hi @dcpanzone,
You're Patches aren't smooth.
I've uploaded a new version.
If my post answers your question Please use  Mark Solutions!.Accept as Solution & Give Kudos!Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
dcpanzone
Jeez, can't believe I missed that. Thanks for the quick response, was really beating my head against the wall on that lol
