- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I think I've tried everything with this one. If we set tool orientation on a toolpath and select a new origin, Fusion always seems to ignore the new origin and sets the CAM figures relative to the setup WCS origin. Surely setting a new origin point should create a new xyz datum?
I've had a look at the post setting here, and that doesn't make any difference. Am I missing something obvious?
I've previously been setting angular datums via an additional setup & tool orientating each tool in that setup to gain the correct B axis position. The additional setups WCS is set to the origin point I want to datum from.
Today I've been trying to use folders instead, overriding the work offset number and (as before) tool orientating each tool to get the correct B axis position.
