Tool offset won't change when adjusting on control
jimMA3D3
Message 1 of 15
jimMA3D3
Hi ,
 Machining a shaft and have added  a pass through M00( Measure) so I can adjust my finish cut if needed. I make my adjustments on machine control, cycle start. the  size still the same. I notice in the post it doesn't call the tool for the finish cycle. It starts where it left off. Is there  away to make you adjustment  then run finish cycle in the Step up in fusion 360.
Replies (14)
Message 2 of 15
seth.madore
Could you share your file so we can see the workflow? Also, what machine is this and what post processor are you using?
Seth Madore
Message 3 of 15
jimMA3D3
I have Doosan 280LM with fanuc i series control. The post processor is a one from Fusions Library Puma.I had a colleague modify it to work.
Message 4 of 15
engineguy
@jimMA3D3
The finishing operation after the M00 stop is not set to the "In Control" option so therefore it is likely that the Post Processor is not outputting the "tool offset call", usually either a G41 or a G42, in your case it is likely to be a G42.
Without your specific Post Processor (I used the Doosan PP with Puma option) I may not have it exact but the image of the code shown in the second image does show that the "tool offset" is being "called" by the G42 line of code when the Finishing Operation is set to the "In Control" option, see images below.
Hope this is of some help 🙂
Compensation set to "In Control" gives you code in second imageCompensation set to "In Control" gives you code in second image
Note the G42 line of codeNote the G42 line of code
Message 5 of 15
jimMA3D3
Thanks for your help. Will give it a go. Have another one for you. I have collision in groove cycle on pulley.
Message 6 of 15
engineguy
@jimMA3D3
That would likely be because the tool cutting sideways at full depth and full width in a single move which Grooving tools don`t like to do 😞
Not likely that a 1mm tool would survive that move but you never know, what material?  🙂
However changing a few settings under the "Passes" tab as shown in the image below would make that Operation a lot easier on the Grooving tool, just a suggestion, it may look like an odd toolpath but should do a nice clean groove safely 🙂 🙂 🙂
Hope this helps a little, that is the area to "play around in" for this stuff, modified file attached 🙂
Message 7 of 15
jimMA3D3
Thankyou for your help. Changed the finish cycle to control on the bagger pulley it changed to G41 not G42. Would it because internal machining vs External machining?
Message 8 of 15
engineguy
@jimMA3D3
Yes, G41 for Internal would sound correct 🙂
Without a copy of your Modified Post Processor I am not able to post the exact same code as you 🙂
Message 9 of 15
jimMA3D3
Have attached modified post.
Message 10 of 15
engineguy
@jimMA3D3
You have uploaded the Fusion f3d file again which still has the Red Collision in the simulation.
Have you not tested the last Fusion file that I uploaded for you ??
What you need to attach is the Post Processor .cps file from your Post Processor Library.
Message 11 of 15
jimMA3D3
Sorry about that. Have attached post.
Message 12 of 15
engineguy
@jimMA3D3
That is just the G code file, which doesn`t have the offset call BTW.
The actual Post Processor from your Post Processor Library that you are using please 🙂 the .cps file.
Message 13 of 15
jimMA3D3
Hi engineguy,
A colleague of mine modified the post processor. Not sure how to send you what you require. Could you show the steps how to do this?
Message 14 of 15
jimMA3D3
Hi ,
I think I found what you require.
Message 15 of 15
engineguy
@jimMA3D3
OK, that Post Processor seems to be producing good code so test it out carefully at the machine 🙂 🙂
