tool library windows expand
Message 1 of 14
when I try to expand view on tool library the command stick or stuck to the bottom edge and then I need to close, library . or else it don't work.
Replies (13)
Message 2 of 14
jhackney1972
Can you attach a screen capture to show the issue?
John Hackney, Retired
Message 3 of 14
when click on bottom bar
Message 4 of 14
jhackney1972
I see not issue by click on the bottom bar or otherwise.  I guess you will need to do a Screencast to show the problem because I do not see any
Message 5 of 14
sorry launch screencast recorder not working. this is the first time I try.
Message 6 of 14
here is screen capture.
Message 7 of 14
etfrench
This is most likely the problem.  Resizing the bottom pane doesn't allow  you to accept the change.  The only available option is to Cancel the resize.  I must say, I'm not a fan of the revamped tool manager.  Every time I open it, I have to change the list order.
ETFrench
Message 8 of 14
jeffery71
Mine does the same thing.. Rather anoying.  Also if I change the sort order of the tools it always defaults back.
Message 9 of 14
MatthewPBryant
Hi @Anonymous,
We currently have a bug where some users cannot release the drag handle when resizing the bottom panel in the new tool library. The team are aware of this and working towards a fix.
@etfrench / @jeffery71 we have also been working on remembering the sort order in the tool library - hopefully you'll see that soon!
Matt Bryant
Sr. Software Engineer
Message 10 of 14
s.noke71
Can you also fix the column resize to stay at the dragged length. this is also very annoying
Message 11 of 14
mattdlr89
+1 for both of these bugs. I was about to post the same.
Message 12 of 14
MatthewPBryant
Hi @s.noke71 ,
Are you referring to the column widths not being remembered when you re-open the library or are you saying that the column drag-handles are not releasable as well as the bottom drag-handle mentioned by @Anonymous? If it's the former, we are aware that some customers have been seeing an issue here and again we're working on a fix which we hope to get out asap. If it's the latter, I'm not sure we were aware of that issue - would you be able to provide a screencast showing the problem, please?
Matt Bryant
Message 13 of 14
go back to message  5 please
Message 14 of 14
I did check today, and is been fixed.
thanks
