Tool libraries, edit tools or new tools?
JonSchaeffer
Message 1 of 8
JonSchaeffer
I am looking for some vision direction in terms of tool libraries.
Right now I am trying to decide which way is the best way to work with these tool libraries.
My goal with the tools is to be able to specificly use the actual tool definitions that will be used to machine the part I am programming.
I want the set up sheet to reflect certain exact information that are critical to the set up person. To have a crash free set up because I controlled these bits of information durring the programming portion.
Example;
1/2 standard lenth end mill
tool extention 1.9
In a stub solid holder
Do I create my own personal tool library based on the actual tools I have in my shop?
if so does this mean I need to do all the leg work on the tool info, flute length, shank, dia, and so on and so on...?
Do I just use what is available within a provided Fusion 360 tool library and edit the tool to what it actualy is?
Right now I am unsure which way to go. I dont want to create a cluttered tool library
I hope this isn't to vague of a question.
www.genesisprecisionaz.com
[email protected]
Replies (7)
Message 2 of 8
curtis.chan
Hi John,
My personal preference would be to do a hybrid of both your responses.  I'd copy/paste the Fusion 360 Tool Libraries to a new library and edit them, along with create custom tools with the correct Tool Holder, Feeds and Speeds etc.  If this new library will be my main library, to minimize clutter, I'd go under  the Tool Library Folder and turn off all the sample libraries and just have my main one show up.
Hope this helps.
Message 3 of 8
JonSchaeffer
So I created a tool HOLDER library, spent most of the day documenting all our holders we have in our shop.
Super excited... for real verification for clearances...
And I came home and opened up Fusion from my home computer and that Library is not there.
I am guessing that this is a local library and not a cloud library?
Is there a way to do this via the cloud and keep my stuff with me at all times no matter where I log in?
[email protected]
Message 4 of 8
HughesTooling
Yes you can do what you want. Make sure you have cloud libraries enabled open the tool manager and select the cloud folder and create a new library. Then go to your local library with your holders and select all of them and drag them to the new cloud library. You can make multiple selections in the library by selecting the tool at the top the holding shift down and picking the tool at the bottom of the library.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 8
JonSchaeffer
ok I did that and all seemed right.
Till I went and logged into another computer and signed into fusion and checked for that cloud library, and it wasn't there.
in fact I came back to my laptop at my toolbox and it was not there as well.
[email protected]
Message 6 of 8
HughesTooling
A360 has been known to delete a library for no reason but I've not had it happen for a long time. Try going to this link then Documents open the CAMTools library and see if the library's there. If not try the trash folder.
It could be you closed Fusion before it had finished uploading the library and you might have to make it again. If you have to do this maybe have a look in A360-Documents-CAMPosts before closing Fusion next time.
Mark
Mark Hughes
Message 7 of 8
JonSchaeffer
Hey thanks for all your help Houghs Tooling...
I really apreciate it.
Im still struggling with this though,
* It is not saving it even on my laptop where I am creating the library...
[email protected]
Message 8 of 8
HughesTooling
When you go to A360 is the CAMTools folder there and have you had any luck with cloud libraries at all, tools, posts or templates.
Mark
Mark Hughes
