Tool drags from WCS to first tool path
- Mute
- Permalink
- Report
Hey y'all,
I'm new to this and I'm having some trouble. After a bit of searching around, I wasn't able to find a solution to my issue. I don't have limit or home switches on my machine and I am setting home manually.
For this project, I set the WCS in the top center of the stock. After manually setting 0, 0, 0 on the machine and I press start, the bit drags along the stock surface to the start of the first tool path. Once there, it moves up to the clearance height then back down and starts milling. How do I fix this so the tool doesn't drag along the stock?
From my understanding, the clearance height it where the tool rapids to before it's moves to the first or next tool path. I have no problem when it moves to the next tool path. The only issue I have is when it moves to the first tool path.
Thanks in advance!
Johnny
