Tool collision with fixture
SGoldthwaite
Message 1 of 19
SGoldthwaite
In this chess piece, I have the round base defined as the fixture.   When using morphed spiral, the tool is going into the fixture.  See picture.   In my setup I enabled Shaft & Holder.  I tried Pull-Away mode and Trimmed, but neither solved the problem.  How do I prevent this?   I attached my F3D file.
Also, I have a 4th rotary axis (rotates on the X-axis).  In the same setup is there a way to rotate the part and mill other parts of the workpiece?  I played around with Tool Orientation setting, but I couldn't figure it out.
Replies (18)
Message 2 of 19
programming2C78B
you will have to limit it via boundaries or avoid surfaces.
Simply change the Z in your tool orientation to how you want the rotary to position itself. What part do you not understand?
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 19
SGoldthwaite
Thanks.  I'm surprised Fusion doesn't just automatically avoid the fixture.   I changed tool containment to Inside boundary, and that keeps the tool from hitting the base/fixture.  But it also reduces machining other areas, which I can live with, but don't prefer.  I tried adding the base to the avoid surfaces option and it made it worse, the tool goes over the base and it looks like it's doing some air cutting. This is with tool containment outside boundary. See picture.
I did figure out the rotation question by selecting a different z-axis.  I don't know why I had trouble the first time I tried, it's pretty straight forward.
Message 4 of 19
programming2C78B
Right now Fixtures are only used for collision detection, not auto-avoidance. It is on the roadmap to start including the fixture in 3D toolpaths as "avoid" regions.
Message 5 of 19
SGoldthwaite
That will be a really useful feature when it's added to Fusion.  It is odd in the picture above that it's doing air cutting on the base since I marked this as an avoid surface.
Message 6 of 19
HughesTooling
Can you share the design? What I think should work is have just the head and create your setup and stock, then in the machining ops add the base under model. Machining should be confined to the stock area and the added base should be avoided.
Mark Hughes
Owner, Hughes Tooling
Message 7 of 19
seth.madore
It's not too far away... 😉
Seth Madore
Message 8 of 19
SGoldthwaite
I shared the F3D file in my original post.  I have made changes since; attached is the latest.
Message 9 of 19
HughesTooling
I guess you're using the insider version so I can't open the file.
Mark Hughes
Message 10 of 19
SGoldthwaite
I am in the insider program.  I didn't think about that.  I don't there's a way for me to save in an older version.
They way I have it now is - In my Setup for the Model section, I have just the knight's body.   It's actually two bodies, the horse's body and the horse's mane.  I have the base as the fixture.  In my machining operation,  I have Model section enabled.  For Model Surfaces I have the base body selected and I enabled "Include Setup Model"  See screenshots.Adaptive Setup.jpgAdaptive Setup.jpgKnight Setup.jpgKnight Setup.jpg
Message 11 of 19
HughesTooling
Sounds like what I was trying to say in post #6. Does it work?
Mark Hughes
Message 12 of 19
SGoldthwaite
I think it worked, although it's not the most efficient toolpath.  As you can see from the screenshot in my last post, the toolpath does go over the top part of the base/fixture, but it seems to be air cutting.  I don't know why it's even going in that area.  I won't know for sure until I actually machine it for real.
Message 13 of 19
HughesTooling
You might get a more efficient toolpath if you set the machining boundary to None and stock to rest like you have it. You might want to create another base with a bit of an offset to give a bit more clearance. Also make sure the staydown distance is not too big to stop the tool trying to move around the bottom of the base, could even make the bottom of the base longer to stop this. So maybe make a slightly bigger diameter base to leave a bit more clearance but also an extra 10mm or more material on the bottom just for the fixture used in the machining ops.
Mark Hughes
Message 14 of 19
programming2C78B
If thats an adaptive, you can make it not do 99% of those retracts!
Message 15 of 19
SGoldthwaite
@programming2C78B wrote:
If that's an adaptive, you can make it not do 99% of those retracts!
It's adaptive roughing.  How do I reduce the retracts?  I have retracts policy set to Min.  Stay down distance is 2 inch and stay down level is most.  Here are my settings:
Message 16 of 19
HughesTooling
Because you are using a boundary you are in effect machining a pocket, if you can set the machining boundary to none it should clear from the outside and produce a more efficient toolpath.
Mark Hughes
Message 17 of 19
SGoldthwaite
Thanks.  I'll give that a try.  This toolpath takes forever to generate, over 30 minutes (with or without the boundary).
Message 18 of 19
programming2C78B
Old computer? Consider splitting the model in half and programming the other side via a pattern or smoothing out your mesh. I imagine this is an STL you converted into a solid?
Message 19 of 19
SGoldthwaite
My computer is pretty beefy - Lenovo ThinkStation P520c,  Intel Xeon W-2123 Processor with vPro (4 cores, 3.60Ghz, 8.25 MB cache), 64 GB RAM.
I did convert STL to a body.  I did some facet reducing on the STL before I imported it to Fusion.  I wish I could have a version that was created in Fusion with the surfacing tools, but I don't have the skill to do that.   I didn't think about patterning, that's a good idea.
