Tolerances and Smoothing - 2D Contours in Plywood
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all,
Just trying to get my head around Tolerances and Smoothing. Just thinking about 2D Contours at the moment, when I get some time I'll do a similar post with data from my 3D Contours.
My goal is to understand how I can minimize machine time in the main by reducing acceleration/deceleration etc.
I have several 100 parts to route out of 20 or so plywood sheets so am ken to optimize as much as possible. While al the parts differ, the one below is typical ( 3mm roughing multiple depths, tabs, "dogbones" in corners and mainly straight lines or large radius arcs/splines.
All milled edges and surfaces of the plywood are glued surfaces to other similar parts so really smooth finishes are not important.
Below are the Fusion 360 Toolpath sizes for Tolerance of 0.01mm and 0.1mm, with and without smoothing the same vlues
Actual file sizes of the NC posts are smaller files shown below.
Now I'm assuming that smaller file sizes are better - ie. more can be sent to the CNC controller potentially.
Also assuming that for my plywood application 0.1mm T and smoothing at 0.1mm will give me a satisfactory finish, I'll create some parts tomorrow.
I do notice that the line of code are reduced with tolerance reduction and smoothing as expected, a good thing for sure.
Estimates for machining time in Fusion for each toolpath are identical - I'm assuming that the optimization using these two parameters doesn't affect machining time as they are not intricate splines or the part has lots of small areas to machine.
So mu conclusion I think is that dropping the tolerance to 0.1mm and adding smoothing of the same at least reduced file size and number of lines of code and that this is good???
am I missing anything?
David
Harrison Classic Boats
Win 10 / I7-11700K @ 4.9GHz / 64Gb RAM / SSD's
