Thread turning dont shows retrect field
jonasZUZ5J
jonasZUZ5J
I created a thread turning toolpath, but under the radii tab is only an option for clearance, but not for retract.
In the online help is a retract field described: http://help.autodesk.com/view/fusion360/ENU/?guid=GUID2F1112F9-C0E5-48A0-9498-C159326C1255
So without an retract field, the tool does a full move back to the clearance setting between each pass.
Im using Win7 with Fusion 2.0.5677
Greetings Jonas
johnswetz1982
I think that is from an old version of Fusion. I think you would want model OD or selection and the offset number would be your retract amount. Thread_Clearance.jpg
