11:31 AM
I having problems with thread milling and not sure what the issue is. I made a hole with mill with a radius of .359.for a 1/2-14 NPT fitting Then setup thread routine using a .372 single flute mill from Maritool
Within THREAD window (Passes)
Right hand
Pitch 0.0714286 in
Pitch diameter offset .08in (Started at 0 and worked up to .08
Visually the threads look fine but the male part will not thread. I am not sure if its the thread or the hole size.
Any thoughts ?
