Thread milling
Thread milling
Thread milling
I having problems with thread milling and not sure what the issue is. I made a hole with mill with a radius of .359.for a 1/2-14 NPT fitting Then setup thread routine using a .372 single flute mill from Maritool
https://www.maritool.com/p16219/Single-Form-Thread-Mill-.372-Diameter-X-1.125-Max-Depth/product_info...
Within THREAD window (Passes)
Right hand
Pitch 0.0714286 in
Pitch diameter offset .08in (Started at 0 and worked up to .08
Visually the threads look fine but the male part will not thread. I am not sure if its the thread or the hole size.
Any thoughts ?
LibertyMachine
An NPT thread is tapered. You will either need to interpolate the hole with a tapered endmill or use a full form NPT threadmill for this to work.
NPT thread dimensions
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
Need to learn about tapered mills. Can you suggest one that will work or direct me to a mill ?
LibertyMachine
Do you have one hole to do? Model it as tapered and surface mill it (Ramp)
Many holes to do? Get a tapered endmill. Unsure of the supplier for that, as I've always used full-form NPT threadmills, which form the taper as they cut. That will likely be more cost effective.
Seth Madore
One hole, I searched for tapered end mills but all I got was tapered mills.  You pointed out the problem and got me on the right track I will have to hit google and you tube.
I found a thread mill for NPT.  IT says the mill has a tapered ground into the mill. Can this also be used for outside cuts ?  Since the taper is only one way I dont understand how it can be used for both inside and outside cuts.
Here is the lakeshore mill
http://www.lakeshorecarbide.com/12-14carbidethreadmillnpt-1.aspx
  • These thread mills are able to produce internal or external threads
Steinwerks
I couldn't think of a great way to explain this without multiple photos, so I found a video:
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
