tcp not working proper in 5 axis machine
i m using the modified generic pp of osai for my simultaneous 5 axis machine.
when i use tcp1 it show positive software overtravel error whenever z is having a positive value.i use uao1.
when i use only tcp with uao1,the xyx axis are ok,but when a and c rotates the programs runs in air.
to use tcp1 i have to change z values in uao1 to make uao1 working.approx -300mm more than tcp.
when making a circular swarf in some big hole say approx 150mm dia,the simulation shows only one rotaion of c axis,but the machine keeps rotaing c axis and the swarf is also of approx double diameter.xy moves very little and c keeps rotating.
its a five axis with infinite C axis rotation mounted on z and a 10 to 90 degree tilting A axis .
please help with the issue.
i attach the pp with this,,please check if any modificatons required in this.
thanking you in advance.
boopathi.sivakumar
@Anonymous
I could not see the attached post,
also does your machine supports tcp or not ?
Boopathi Sivakumar
Senior Technology Consultant
thanks for the reply sir,yes the machine supports tcp. kindly find the attached pp
