Tapered Variable Pitch Thread
Message 1 of 8
 Does anyone know how generate a tool-path for a tapered variable pitch thread similar to the parts at the link below. Can this type of tool path be generated for use with a lathe or a 4th axis on a milling machine?
Replies (7)
Message 2 of 8
Steinwerks
I would not be using Fusion for these parts honestly. This is a level of complexity that would likely suit something like Hypermill or Powermill and multiaxis grinding software to finish.
Neal Stein
New to Fusion 360 CAM? Click here for an introduction to 2D Milling, here for 2D Turning.
Find me on:
Instagram and YouTube
Message 3 of 8
Can it be done with Powermill? I think that there is a free trial so i may download that & see how user friendly it is. (I love Fusion for that reason but it seems limited in a few areas. Still a great program thou don't get me wrong.)
Message 4 of 8
Steinwerks
Honestly I am not sure offhand, it was just a thought. I have opened it a few times but it is vastly different than HSM and have not put any real time into learning it. There are a few videos on YouTube for getting started. I also can't speak to what posts it has available or through whom you'd find support (presumably resellers).
Neal Stein
Find me on:
Message 5 of 8
Okay, thanks for your input. I may also give the HSM a try & see about maybe using it for things like these. Again, depending on how user friendly it is. (That's the one thing that I love about Fusion 360. It is very user friendly)
Message 6 of 8
balsmen
Hi @Anonymous,
Just want to clear up any confusion, but the HSM CAM kernel is what powers the CAM in Fusion (as well as Inventor HSM and HSMWorks), which as @Steinwerks mentioned, is not very well-equipped to handle the workflow you are trying to use.
Noah
Noah Balsmeyer
Fusion Mfg Software Engineer
Message 7 of 8
Thanks, I'll have to figure something out. Maybe the Powermill can do the trick.
Message 8 of 8
Hey guys, just an FYI: I was able to get fusion to do the trick. The trick is to split the shaft into halves & then generate the tool paths for each half of the shaft using the 3d milling tool-paths instead of wrapping the tool paths around the shaft. I have to admit that it's not "perfect" but it will do the trick with a little clean-up / sanding in the lathe. Just thought that I'd let you guys know in case anyone else had the same question. BTW: I did download the Autodesk Powermill software & was not able to do jack with it. Fusion seems like better software by far.
