Swarf toolpath troubles, tool won't follow geometry
Loek_vanbruggen
Loek_vanbruggen
Hi there,
I am new to fusion 360 (experienced in Solidworks and inventor) and am trying to make a multiaxis swarf toolpath to chamfer my part (see the desired result in foto 1). I tried all kinds of selecting but could not get the program to give me a good toolpath.
the way i got the best results but not final was by selecting the countour edges manualy but this doesnt work completly, when i get to a sertain point the blue and yellow lines flip, but they dont flip on the first part (see foto Swarf edges).
the flipping of these lines make the rool go inverted when it gets to those lines , (rams tru stock, part and mounting, collisions).
im sorry if this is a realy basic thing im doing wrong but does annyone know what im missing?
Thanks a lot for your time.
best regards Loek
seth.madore
Could you share your Fusion file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply
Seth Madore
Laurens-3DTechDraw
Yeah the part here would massively help as this doesn't seem like it should be hard at all.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Loek_vanbruggen
I'm not sure if it got al the components. I hope it did 😃
here is the file
thank you for helping
Laurens-3DTechDraw
Hi Man,
This one was easy. The selections are a lot easier if you set the Tool Orientation as I do in this example. The chaining algorithm than picks up what you want much easier. I still like to start with alt to start with a single chain, but can also pick a closed contour and then change to an open one. Probably the same amount of clicks.
I think it's pretty straightforward from there.
(view in My Videos)
Laurens Wijnschenk
3DTechDraw
loekvbrc
Observer
Observer
Thx
Awesome, thx for looking in to it.
im out of office for a week so i wil let you know if i get it to work, my hopes are high😁
awesome guys, thx
