Suggestion for tool path settings within nested sheets
- Mute
- Permalink
- Report
As a cabinet maker, I use the nesting feature daily and I have two complaints that if addressed would be a significant improvement to my workflow.
1. When using the select all feature, there is no way I'm aware of to deselect individual components. Sometimes within a large nest there is a need to deselect 1 or 2 parts that require a different tool path or different settings for tabs. It seems like there should be an easy way to make this possible.
2. When cutting rabbet joints (open ended pockets) on the edge of a nested part, Fusion thinks it can plunge outside the component and not collide with the existing stock. I can't seem to find any option to avoid this, despite having a ramp set up in the linking tab. This causes unnecessary tool wear because the tool is plunging directly into the existing stock.
I have done some research on both of these issues and can't come up with any answers. Is this something Autodesk could look into? They seem like easy fixes.
