Strange and Unwanted Tool Path Generated
mkilloran38SZU
Message 1 of 18
mkilloran38SZU
Hello Everyone,
I'm working on expanding one of our injection molds so its thick and have finally been I'm making chips this week. I have been taking off .010" each operation to get the desired expansion to .050" on the radius, .100" on the ID in the mold, without much issue until now. I'm going to take it do to .010" of the finished ID and decided to change the stepdown from .040" (default it was set to) to .005" to get a smoother finish and less polishing at the end. What I am getting now is that the tool path generated is mushrooming at the top, as in its going farther away from center than I want and its going to ruin the mold. Can someone help explain why its doing it and how to correct it? The walls have a 3 degree taper. My boss is worried it will make a radius at the top of the model and we cannot have that as it needs to mate to the other side of the mold.
It will be Contour 6 is the specific operation in the file
Replies (17)
Message 2 of 18
UTD7ZNYB
That's because it's being machined using the tip of a ball end mill.
It can be avoided by using an extended body.
Message 3 of 18
a.laasW8M6T
This is a very annoying and unintuitive thing about avoid surfaces.(And Boundaries)
There is a tolerance that the toolpath works to and that means that it can work right up to the surface.
To prevent this from happening you can add a small radial clearance equal to the toolpath tolerance
On contour6(2) i show a different method using boundaries
You must turn on Contact point boundary and use a negative additional offset equal to the tolerance
Andrew Laas
Senior Machinist, Scott Automation
Message 4 of 18
mkilloran38SZU
I tried extending the body and still getting the same thing. Is there something else I'm missing in conjunction with extending the body?
Message 5 of 18
programming2C78B
Are you adding the extended body into your Model selection for that toolpath?
Please click "Accept Solution" if what I wrote solved your issue!
Message 6 of 18
mkilloran38SZU
I extended it, kept them as two separate bodies and said to avoid the extension so it doesn't try to mill it. Not sure if that is correct thing to do.
Message 7 of 18
a.laasW8M6T
@mkilloran38SZU I wouldn't bother with the extended body(It does work If you do it right though)
Just add the small radial(or axial) offset to your Avoid surfaces like I show in My file, much less effort
Andrew Laas
Message 8 of 18
mkilloran38SZU
when I do that, it starts milling what looks like half an inch lower than I want. Does that look right or is it a visual glitch?
Also thank you for helping
Message 9 of 18
a.laasW8M6T
That is correct
You have a .5" ball nose so it starts where the contact point of the tool meets the work piece.
If you want to start higher but not have the tool roll over then use an extended body or surface and add to the machine groups
You will just end up cutting air for a while though
Andrew Laas
Message 10 of 18
mkilloran38SZU
Awesome, this is what I was hoping to do. I'm going to give it a try and see how it goes. Is there a way to do a continuous flow, without the retracts and rapid movement, that aren't at the beginning and end, on what looks like the first lap around? (the red, yellow and green lines in my screenshot) With your knowledge, I feel like its a setting right in front of me and I don't realize it
Message 11 of 18
a.laasW8M6T
Hi
Sorry should have had the clearance in the axial instead of radial(I found a bug yesterday while I was messing around so got distracted)
If you use 0.001 clearance it cleans right up
Andrew Laas
Message 12 of 18
mkilloran38SZU
I change those settings and still have the same issue. Could there be another setting that could affect it? Again thank you for your help. I'm learning a lot more from you than from fusion help
Message 13 of 18
a.laasW8M6T
Ahh
Looks like I had increased the tolerance in the passes tab slightly too
Another option is to right click on the toolpath and go into compare and edit and change the surface triangulation tolerance to tolerance x0.1(default is tolerancex0.5)
I would also turn on smoothing, Much nicer code.
No smoothing, Thousands of points:
Smoothing on
very few points with nice arc moves
Andrew Laas
Message 14 of 18
mkilloran38SZU
I already had smoothing turned on but the big thing I see is that you have the maximum stepdown as .0005 and I have it at .005. I tried both numbers and it still is happening. I didn't install and setup fusion here, a previous guy did, and he was very particular about things so I have no idea what he could have done.
edit: nevermind on the stepdown. i miss read it. we have the same
Message 15 of 18
a.laasW8M6T
I have changed a bunch of defaults over the years to get toolpaths how I like, but I have just tweaked a few things on your file to get it to work.
see attached
You can upload this one and copy My good toolpath into your setup, then select both and right click, compare and edit and select different to see what the different settings are
Andrew Laas
Message 16 of 18
mkilloran38SZU
Thank you so much for your help on all of this. When I copied your tool path, it lost what defined the bottom height. What did you have it set too so it can't change things: the bottom of the model or the bottom of the big radius?
Also, when I select what is different in the settings, the window is blank.
Message 17 of 18
a.laasW8M6T
you have the file to see what selections I had too.
just look at at that to see what selected for heights etc, I haven't changed much from your original file in terms of that.
Andrew Laas
Message 18 of 18
programming2C78B
"the window is blank."
You probably only had one toolpath selected.
