Stock to leave error
Message 1 of 13
Hi, sometimes with thin wall features I "face" them by using a contour toolpath.
However, in this example, I was facing this one with a ball nose mill and thus needed to do a stepover slightly over the tool radius.
Problem is, I get this error.
Is this a problem of behind-the-scenes geometry and programming, or is this an arbitrary constraint imposed by HSM?
Aside from sketching an offset chain, is there another way to do this?
Replies (12)
Message 2 of 13
jeff.walters
Instead of selecting the outer edge can you select the hole edge?
Jeff Walters
Senior Support Engineer, CAM
Message 3 of 13
I can, but what does that accomplish?
Message 4 of 13
jeff.walters
you can then change the arrow to the outside and use a postive offset.
Jeff Walters
Message 5 of 13
That moves the tool off the thin feature.
Message 6 of 13
jeff.walters
i just noticed that you have the 3D operations have you tried the 3D horizontal before?
Jeff Walters
Message 7 of 13
kb9ydn
I'm sort of confused as to why you would want to face these parts with a ball mill?  You don't mean to deburr the edge?
C|
Message 8 of 13
because with such a thin wall part you can do two quick passes and get an acceptable result without having to have a 2 tool operation. I'm stuck with manual tool changes 😞
Message 9 of 13
jeff.walters
It sounds like in this case you’re better off using a sketch and trace then.
Jeff Walters
Message 10 of 13
Message 11 of 13
kb9ydn
Oooohhhh, ok  That makes sense then.
As far as I know it's a mostly arbitrary limitation, although I seem to recall that allowing it to be more than 1x tool radius negative caused some issue with something I forget.  This was brought up on the CAM forum awhile back by a particular user that REALLY wanted it.  I think everyone else was just sort of... meh.
I would (also) say try the horizontal strategy.  The settings work a little differently from 2D contour but should be pretty simple to make it do what you want.
C|
Message 12 of 13
jeff.walters
It’s not an arbitrary limitation I don’t remember the exact reason for it but it is by designee. I have attached a sample of doing your part using 3D horizontal.
Jeff Walters
Message 13 of 13
Thanks Jeff!
