Stock Comparison for CAM
Hi There,
I am missing a function to compare the simulated stock with the model. In HSM exists a checkbox that opens a colored material comparison. When will this be availeble for Fusion 360. Is is quite essential for professional use.
Regards
Andreas
HughesTooling
It's been requested a few times. For now you can get some feed back from the info tab on the simulation dialog, Distance show the amount of material under the mouse pointer.
Mark
Mark Hughes
Owner, Hughes Tooling
... thanks for the info Mark. This will help a bit, but only on small/easy models. If the model is bigger or more complex you will surely miss some areas with rest material.  Is there a concret plan to implement this function (again: in HSM it already exisits). It is a basic function of most of the major CAM software in the market.
Andreas
CsFuzi
Any news?
Totally agree with Andreas...
The  function to compare the simulated stock with the model is quite essential for professional use.
Csaba
It has been four years now!
It is an essential feature, the community is asking for it, and Autodesk simply ignores it!
Not addressing the request shows how the customer is valued!
LibertyMachine
Oh knock it off. There is certainly value for the customer, as without us, Autodesk/Fusion360 wouldn't exist. The reality is that there are 1000's of awesome ideas that need to make it into the product and there is a constant balancing of hierarchy of importance. It's not an unlimited development team, so the chances of everyone's "essential feature" making it into Fusion in a timely fashion is very low. We do have Stock Comparison of sorts via the "Comparison" option. That doesn't give direct measurement ability, but will flag us if there is something with large deviation. Still, that needs work, and they are aware.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
