Stock alignment issue
Message 1 of 10
I'm trying to cut this on a 3+1 operation and this is what my stock looks like.  I can't seem to figure out how to get my stock to align.
Replies (9)
Message 2 of 10
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
The stock orientation is driven by your WCS orientation. If that is your WCS orientation, then I would recommend modeling your stock and using 'from solid' as your stock selection.
Cheers,
Karina
Message 3 of 10
seth.madore
Hmm...
Can you share your file?
File > Export > Save to local folder, return to thread and attach the .f3d file in your reply. If it's sensitive info, you can PM me the A360 link, which you can find by right clicking on the file in the data panel.
Seth Madore
Message 4 of 10
Here's the file
Message 5 of 10
seth.madore
Hmmm.....I'm not seeing the file. Try again?
If it's an assembly, you will need to export it as an .f3z file, put it in a .zip folder and then attach that folder to your next reply (.f3z is not yet supported on the forums)
Seth Madore
Message 6 of 10
seth.madore
Thanks for PM'ing me the file!
So, looking at "Model for Matt" Setup and program, I'm not seeing the issue:
Is there a certain workflow that you were following to get the inaccurate results earlier?
Seth Madore
Message 7 of 10
It works fine for milling...but when I try turning then I get bad results.
Message 8 of 10
seth.madore
Ok, I think I see that now. I was able to replicate the issue you are seeing, but, while it's a bug, I'm not seeing it as a Setup that would actually work, since the chosen Z axis is not in line with any turned feature. Are you looking at turning the .300" diameter shaft?  Can you share a bit of your machining intent so I can better understand what you are trying to accomplish?
Seth Madore
Message 9 of 10
I will be using a 3+1 axis operation.  Yes, the .300" diameter shaft is just there in order to rotate the part.
Message 10 of 10
Here is a previous part I built and this is the setup I am trying to replicateLeg2.PNG
