Spot Drill Template - Expression Help needed
Koch612
Message 1 of 1
Koch612
I'm currently working on a spotdrilling template in Fusion.
Example:
Spot drill 142° Dia. 12mm
I want to spot drill all holes with diameter 5-11mm but want to spot only 3/4 of the diameter. So in the heights I need a formula for the depth. Something like Diameter = hole diameter/0.75 but I don't find a expression for the hole diameter. Until now I have to do this for every hole diameter by itself which isn't that productive.
Does Fusion has a expression for Hole diameter?
Replies (0)
